tonyd
(Tony DAngelo)
August 23, 2019, 7:12am
1
I’m getting ready to start my final assembly on my first MPCNC, 24 x 24 two questions.
z gantry height I was thinking 6" should I go lower? 4" or 3"? I’m thinking 3" would be tight if the bit is 1.5?
Second question, The tool mount, there is a 4mm and a 6-32" witch one do i use? (I printed both) i can’t see a deference in them.
I have a feeling I’m going to feel dumb when i get this answer.
Thanks in advance.
Tony
I’m pretty sure the difference between the tool mounts is the size of the hole for nuts. I printed the 6-32 and the nuts were snug.
ghostman1
(Mike Atencio)
August 23, 2019, 10:25am
3
Per Ryan, “The higher, the more unstable” 3 or 4" is good. If you need more Z, build your table with a hole in the middle to go lower. Then you can get up to 6" Z height as long as your piece is below your tabletop. 3 inches above and 3 inches below.
Only one of the nuts will fit. Easy, the other won’t fit.
tonyd
(Tony DAngelo)
August 23, 2019, 12:46pm
4
I’ll go 4" on the z AS this is my first endeavor i don’t want to make it to default to get started.
Thanks
Tony
mallek
(Hobbytime)
August 23, 2019, 1:28pm
5
What LED controller case is that? looks nice
tonyd
(Tony DAngelo)
August 23, 2019, 3:10pm
6
I like it, you can tell the guy put some thought in to it,
best regards
Tony
