Ok so I’m making tool paths for my next cabinet cut, and I’m having issues. Mostly because I’ve never programmed rabbets, usually do them by hand with my router after the fact.
I use Estlcam, and I can cut the dadoes easily using the peel as recommended in the help files, but what about rabbet cuts? I tried using the peel but that clearly wasn’t right, because it only allowed me to do part of the tool path that way. BUT, if I choose linear as my method, it shows the tool path all the way up the cut as it’s supposed to be.
So my question really is, am I doing this right? Choosing ‘Hole’, then making the part I want to Rabbet a pocket? Or is there another way to achieve this?
And is linear a good idea for a LR2? Or nah?
