Hi! Finally got my mpcnc primo up and running tonight! Dual endstops.
I connected it through Repetier and verified the endstops and squared with M666.
I realized my Z was moving in the wrong direction, powered off, and switched the plug.
When I tried to reconnect, the lcd reboots, and the Repetier log gets filled with rubbish.
This has happen once or twice before, but was always resolved by disconnect everything and reconnect.
However, this time the issue is persistent.
Any thoughts on what could be the issue?
Thanks in advance!
Repetier log:
21:38:34: Attempting to connect to printer
21:38:34: Connection opened
< 21:38:35: echo:start
> 21:38:35: N1 M110 *2
< 21:38:35: Marlin 510D 2.0.7.2
> 21:38:35: N2 M110 *1
> 21:38:35: N3 M115 *5
< 21:38:35: echo: Last Updated: 2020-10-15 | Author: (V1 Engineering, Ryan, 510D)
< 21:38:35: echo:Compiled: Jun 4 2021
> 21:38:35: N5 M111 S6 *66
< 21:38:35: echo: Free Memory: 3285 PlannerBufferBytes: 1552
> 21:38:35: N6 M111 S6 *65
< 21:38:42: DIGIPOTS Loading
< 21:38:42: DIGIPOTS Loaded
< 21:38:42: echo:V82 stored settings retrieved (649 bytes; crc 11782)
< 21:38:42: echo:Unknown command: "echo:start"
< 21:38:42: echo:Unknown command: "Marlin 510D 2.0.7.2"
< 21:38:42: echo:Unknown command: "echo: Last Updated: 2020-10-15 | Author: (V1 Engineering, Ryan, 510D)"
< 21:38:42: echo:Unknown command: "echo:Compiled: Jun 4 202echo:Unknown command: "echo:start""
< 21:38:42: echo:Unknown command: "ok"
< 21:38:42: echo:Unknown command: "echo:Unknown command: "Marlin 510D 2.0.7.2""
< 21:38:42: echo:Unknown command: "echo:Unknown command: "echo: Last Updated: 2020-10-15 | Author: (V1 Engineering, Ryan, 510D)""
< 21:38:42: echo:Unknown command: "echo:Unknown command: "echo:Cok"
< 21:38:42: echo:Unknown command: "echo:Unknown command: "ok""
< 21:38:42: echo:Unknown command: "echo:Unknown command: "echo:Unknown command: "Marlin 510D 2.0.7.2k"
< 21:38:42: echo:Unknown command: "echo:Unknown command: "echok"
< 21:38:42: echo:Unknown command: "ek"
< 21:38:42: echo:Unknown command: "echo:Unknown command: "echo:Unknown command: "echo:Cok""
