I haven’t been able to use my MPCNC in about a month and turned it on today and found out that nothing seems to work. My LCD screen just blinks on and off without anything being displayed and my LED2 light on the board just blinks. I have unplugged everything and it seems to do the same with the steppers and LCD plugged in or left out. My setup was left unplugged and nothing was moved since the last time I use it. (I purchased my kit from here rambo1.4a)
I do have the 12vdc attached to the board which makes the green led2 flash on and off. Also,for me it is com5 and I do see the TX and RX lights flash once the USB is connected(I know that doesn’t mean much). I believe I can communicate to the device because it seems to read the device info. Unless they give you a generic read out. I have switched the com ports also and it gives me a different error.
