I’m in the final steps of finishing MPCNC build (everything purchased from V1) and I went to run the software setup and my Rambo does not seem to power up. I’m using the standard power supply connected as shown in the attached pic. The power indicator lights on the Rambo do not light up when connected to the power supply or USB. Windows does recognize the board and I followed all the instructions to install the Arduino drivers. When I connect via Repetier, the button turns blue at the top and it seems I’m connected but the program cant send instructions to the board or move the motors. The entire system seems dead.
I would think at a minimum the LED indicator on the board should light up if it has the appropriate power connection?
I confirmed that the AC adapter is putting out 27v. I actually have two identical AC adapters, one from the original kit and one off amazon. Both output exactly the same voltage. Also, I visibly inspected the fuses and they seem fine.
