My RAMBO losing its serial connection at random and I am wondering if I need to update the RAMBO firmware.
I got the crown to draw and got the dual endstops and the Z probe working properly and I am in the middle of drawing a rectangle so I can check squareness and height. I bought “Mostly Printed CNC Parts Bundle - 6A / RAMBo Dual Firmware & Wire kit” which is reporting to Octoprint
Recv: start
Recv: echo:Marlin bugfix-2.0.x
Send: N0 M110 N0*125
Recv:
Recv: echo: Last Updated: 2018-01-20 | Author: (V1 Engineering, Ryan, 302)
Recv: echo:Compiled: Sep 21 2019
I tried using Estlcam from my Windows laptop but it never connected, so I went ahead with OctoPi on a Raspberry Pi (which is what I want anyways) and this seems to work. The video feed is cool. I’m connected using hardwired Ethernet into a 5 port gig switch so no WiFi issues.
Now I get random error messages every 20 minutes or so from Octoprint
" Error reported by printer
Your printer’s firmware reported an error. Due to that OctoPrint will disconnect. Reported error: Printer halted. kill() called!
I ssh-ed into the RPi and the octoprint log has some "echo:busy: processing messages
| Recv: T:170.00 /0.00 @:0
| Recv: echo:busy: processing
| Recv: Error:Printer halted. kill() called!
2021-01-14 15:44:00,202 - octoprint.util.comm - INFO - Changing monitoring state from “Operational” to “Error: Printer halted. kill() called!”
2021-01-14 15:44:00,207 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2021-01-14 15:44:00,223 - octoprint.util.comm - INFO - Changing monitoring state from “Error: Printer halted. kill() called!” to “Offline (Error: Printer halted. kill() called!)”
Should I assume that it is the RAMBO that is busy?
The RPi is a version 3 model B which while not the latest should be overkill for this.
My best guess is that Estlcam and Octoprint are incompatible with the version of the RAMBO firmware. Do I need to update the RAMBO?
