I had it happen on the last two boards I was trying to cut. A different spot each time. First time it was just a few minutes into the cut. Second time it was about 17 minutes into the program. Weird part is, both reboots was right after a plunge to start cutting the next layer.
Could it be a bad SD Card? It’s a cheap one from Microcenter that I’ve had a year now.
What else would cause this?
Ramps board was bought from this site. Marlin 1.0.7 ( I think. Whatever was shipping a year ago). Board has been rock solid up until today.
It happened shortly after I turned the Shop Vac Off the second time. Not sure if I was turning the shop vac on/off the first time. One thing I just remembered is I’m running it on a longer extension cord today. I have a reel with 4 plugs on it. Today I have that plugged into another extension cord instead of going all the way to the wall with it. You think it might be a brown-out?
nah. I don’t have anything else on this circuit. It’s just the garage, front porch and front porch light.
The only other thing I can think is if I have a Z stepper driver overheating.
I finally got a full cut out of this design by going to a ramp down instead of the plunge. This makes me think the z-speed might be related. What is an appropriate Z up/down speed?
The reason why I say this, is on the second board I cut, it was drilling a bunch of holes and towards the end it suddenly stopped going up all the way. I noticed after the cut was done that there was a paper towel blocking half the inlet on one of the cooling fans over the Ramps board right above the Z stepper.
I opened up the case and felt the heat sinks and none of them were hot, but the program had been stopped for a few minutes at this point.
Not sure on the units. There’s none in the config file.
Honestly… ESTLCam or Inventor CAM are about the same. I get just as pissed at ESTLCam when I use it as Inventor’s CAM. Once you learn the workflow, it’s just getting the values correct.
Well I have no idea. The pp settings are correct, no fridge or compressor, no loose wires or dark pins.
1-What are the driver voltages reading while the steppers are engaged?
2-Upload your gcode (zip it first, or cut and paste the first 50-100 or so lines), just to make sure the PP is doing it’s job?
If it is not one of these two options there is literally nothing left other than a ghost. It has to be bad gcode, bad wiring (stepper or power), poorly set driver, or ghost. Last ditch effort is re-flash the board but I doubt that has anything to do with it.
I thought I put this in this post, but it may have only gone into the other one I made…
I’m wondering if the z-height issue might be related to two things.
I noticed there was something covering half the fan inlet on my box covering the RAMPs board... specifically right over the fan blowing on the Z stepper driver.
I noticed my Z axis seems to have some slack/give in both the x and y plane. If you grab the top and bottom, you can kind of wiggle it back and forth a little.
I'm also wondering if there isn't some sawdust stuck in the threads somewhere that might be causing it to occasionally bind. I noticed some of the bearings weren't spinning on Sunday, so I grabbed the compressor and blew them all out.
I guess none of those should be causing the ramps to occasionally reboot, though. I won’t rule out the power supply. It’s a cheap Chinese one that came with my 3d printer. It doesn’t have a cooling fan on it, but it wasn’t exactly hot outside this weekend either… and it ran fine all last summer.
I might try pulling all the hardware out of the little enclosed area it’s currently installed. It’ll help with monitoring things while it’s running.
The only other thing I just thought of, is I wonder if I have a bad stepper motor. I had those z-axis stepper driver issues last summer and I replaced the driver… then I have the voltage configured wrong for a little while and the stepper motor was running really hot.
I fixed that and the motor doesn’t run hot anymore, but I wonder if the motor got damage in the process and is occasionally shorting out internally or something.
What size stepper motor should I be running on my Z? I can try picking up a new one.
