Ramps Troubleshooting Help
I reworked the wiring on my MPCNC to get things cleaned up and tidy. After reconnecting everything none of the steppers will work. I am using Repetier and I connect to the Arduino fine, I can issue commands and see the endstop status changes, etc. I can issue commands to move the steppers and I don’t get any errors, I just don’t get any movement. I am including the output in Repetier below. Where should I start troubleshooting this?
6:32:56 PM: Connection opened
< 6:33:05 PM: start
> 6:33:05 PM: N1 M110 *2
< 6:33:05 PM: echo:Marlin1.0.2
> 6:33:05 PM: N2 M115 *4
< 6:33:05 PM: echo: Last Updated: Feb 18 2016 11_25_1517:51:08 | Author: PID, ALLTED
< 6:33:05 PM: Compiled: Feb 18 2016
> 6:33:05 PM: N4 M111 S6 *67
< 6:33:05 PM: echo: Free Memory: 3397 PlannerBufferBytes: 1232
> 6:33:05 PM: N5 M111 S6 *66
< 6:33:05 PM: echo:Hardcoded Default Settings Loaded
< 6:33:05 PM: echo:Steps per unit:
< 6:33:05 PM: echo: M92 X200.00 Y200.00 Z4535.44 E200.00
< 6:33:05 PM: echo:Maximum feedrates (mm/s):
< 6:33:05 PM: echo: M203 X195.00 Y195.00 Z8.70 E25.00
< 6:33:05 PM: echo:Maximum Acceleration (mm/s2):
< 6:33:05 PM: echo: M201 X400 Y400 Z55 E800
< 6:33:05 PM: echo:Acceleration: S=acceleration, T=retract acceleration
< 6:33:05 PM: echo: M204 S400.00 T800.00
< 6:33:05 PM: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
< 6:33:05 PM: echo: M205 S0.00 T0.00 B20000 X4.00 Z0.40 E5.00
< 6:33:05 PM: echo:Home offset (mm):
< 6:33:05 PM: echo: M206 X0.00 Y0.00 Z0.00
< 6:33:05 PM: echo:PID settings:
< 6:33:05 PM: echo: M301 P12.03 I0.60 D60.60
< 6:33:05 PM: echo:Filament settings: Disabled
< 6:33:05 PM: echo:Z-Probe Offset (mm):
< 6:33:05 PM: echo: M851 Z0.00
< 6:33:09 PM: echo:SD init fail
< 6:33:09 PM: FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:MPCNC EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
> 6:33:14 PM: N12 M119 *57
< 6:33:14 PM: Reporting endstop status
< 6:33:14 PM: x_min: TRIGGERED
< 6:33:14 PM: x_max: open
< 6:33:14 PM: y_min: open
< 6:33:14 PM: y_max: open
< 6:33:14 PM: z_min: TRIGGERED
< 6:33:14 PM: z_max: TRIGGERED
> 6:33:19 PM: N18 G91 *8
> 6:33:19 PM: N19 G1 X10.00 F3600.00 *42
> 6:33:19 PM: N20 G90 *2
> 6:33:24 PM: N26 G91 *5
> 6:33:24 PM: N27 G1 X10.00 F3600.00 *39
> 6:33:24 PM: N28 G90 *10
> 6:33:51 PM: N55 G91 *1
> 6:33:51 PM: N56 G1 X100.00 F3600.00 *17
> 6:33:51 PM: N57 G90 *2
> 6:43:42 PM: N622 G29 *52
> 6:47:56 PM: N860 M119 *4
< 6:47:56 PM: Reporting endstop status
< 6:47:56 PM: x_min: TRIGGERED
< 6:47:56 PM: x_max: open
< 6:47:56 PM: y_min: open
< 6:47:56 PM: y_max: open
< 6:47:56 PM: z_min: TRIGGERED
< 6:47:56 PM: z_max: TRIGGERED
> 6:48:13 PM: N877 M119 *2
< 6:48:13 PM: Reporting endstop status
< 6:48:13 PM: x_min: open
< 6:48:13 PM: x_max: open
< 6:48:13 PM: y_min: open
< 6:48:13 PM: y_max: open
< 6:48:13 PM: z_min: TRIGGERED
< 6:48:13 PM: z_max: TRIGGERED
> 6:48:15 PM: N880 G91 *49
> 6:48:15 PM: N881 G1 X10.00 F3600.00 *19
> 6:48:15 PM: N882 G90 *50
> 6:48:17 PM: N885 G91 *52
> 6:48:17 PM: N886 G1 X10.00 F3600.00 *20
> 6:48:17 PM: N887 G90 *55
> 6:48:18 PM: N888 G91 *57
> 6:48:18 PM: N889 G1 X10.00 F3600.00 *27
> 6:48:18 PM: N890 G90 *49
> 6:48:19 PM: N893 G91 *51
> 6:48:19 PM: N894 G1 X10.00 F3600.00 *23
> 6:48:19 PM: N895 G90 *52
> 6:48:20 PM: N896 G91 *54
> 6:48:20 PM: N897 G1 X10.00 F3600.00 *20
> 6:48:20 PM: N898 G90 *57
> 6:50:26 PM: N1021 G91 *3
> 6:50:26 PM: N1022 G1 X-10.00 F3600.00 *14
> 6:50:26 PM: N1023 G90 *0
> 6:50:27 PM: N1025 G91 *7
> 6:50:27 PM: N1026 G1 X-10.00 F3600.00 *10
> 6:50:27 PM: N1027 G90 *4
> 6:50:28 PM: N1029 G91 *11
> 6:50:28 PM: N1030 G1 X-10.00 F3600.00 *13
> 6:50:28 PM: N1031 G90 *3
> 6:50:29 PM: N1033 G91 *0
> 6:50:29 PM: N1034 G1 X-10.00 F3600.00 *9
> 6:50:29 PM: N1035 G90 *7
> 6:50:30 PM: N1037 G91 *4
> 6:50:30 PM: N1038 G1 X-10.00 F3600.00 *5
> 6:50:30 PM: N1039 G90 *11
> 6:50:31 PM: N1041 G91 *5
> 6:50:31 PM: N1042 G1 X-10.00 F3600.00 *8
> 6:50:31 PM: N1043 G90 *6
> 6:50:32 PM: N1045 G91 *1
> 6:50:32 PM: N1046 G1 X-10.00 F3600.00 *12
> 6:50:32 PM: N1047 G90 *2
> 6:50:33 PM: N1048 G91 *12
> 6:50:33 PM: N1049 G1 X-10.00 F3600.00 *3
> 6:50:33 PM: N1050 G90 *4
> 6:50:35 PM: N1053 G91 *6
> 6:50:35 PM: N1054 G1 X-10.00 F3600.00 *15
> 6:50:35 PM: N1055 G90 *1
> 6:50:36 PM: N1058 G91 *13
> 6:50:36 PM: N1059 G1 X-10.00 F3600.00 *2
> 6:50:36 PM: N1060 G90 *7
> 6:50:42 PM: N1066 G91 *0
> 6:50:42 PM: N1067 G1 X10.00 F3600.00 *34
> 6:50:42 PM: N1068 G90 *15
> 6:50:42 PM: N1070 G91 *7
> 6:50:42 PM: N1071 G1 X10.00 F3600.00 *37
> 6:50:42 PM: N1072 G90 *4
> 6:50:42 PM: N1073 G91 *4
> 6:50:42 PM: N1074 G1 X10.00 F3600.00 *32
> 6:50:42 PM: N1075 G90 *3
I should add that I have disconnected everything from the ramps with the exception of one stepper directly to the X Axis and the resistor on T0. I have tried it on Y and Z as well with the same result.
All your endstops show triggered. Double check them
grrrrr endstops…
Removed end stops, no change. Is there a way to test the output from the steppers?
Not other than them moving. Does your gcode still say endstop TRIGGERED?
Are you using my firmware? None of mine say anything about the endstops at the startup.
le choix des procedes de fabrication, des equipements de travail, des substances ou preparations chimiques, http://santemeds.com/acheter-vpxl-fr.html Notre site est exempt d’annonces publicitaires, vous pouvez donc vous concentrer uniquement sur des informations pertinentes sans que vous soyez distraits, chaque seconde, par les annonces incessantes.
