I have been pocketing some 10mm diamater holes 2mm deep with 0.2mm depth per cut. I am running a Rambo 1.4 board from a Microsoft Surface 3 running repetier host with gcode generated from Estlcam.
Some of the holes look absolutely perfect but then some are 3/4 moon shaped. The strange thing is that if a repeat the code again, it is not always the same holes that generate the 3/4 moon shape. Some holes appear to be 3/4moon all the way though, some seem to hit this shape part way down the cut.
Any thoughts on what could be causing this? Maybe its dirty causing slipping?
Usually it is GCode with incorrect feeds and speeds included. Make sure every line is showing an “Fxxxx” at the end. If they all have it make sure teh Z axis is 8mm/s (F480) or less (it can go faster but this is best for troubleshooting).
Thanks for the response. It seems my grub screws were loose and this was actually throwing the machine out. Simple check I should I should have done. Is there a quick check list for servicing the machine and routine maintenance?
