my name is Michael, I am from Austria and want to show you some of my builds I have made with the MPCNC.
These cutting boards are made from pear wood. I have cut the outer lines, the groove and the letters with the MPCNC and filled the letters afterwards with epoxy. after sanding it has a very smooth surface. I used a 1mm bit for the letters which works fine.
Attached you can find some similar projects with epoxy, the fish one is my favourite - it’s perfect for filleting fish. For all of these projects I used pear or apple wood.
Here is a second picture, I cut the metal fish on the sides with the laser at work.
Love that the MPCNC allows to machine wood that is way bigger than its working area!
Burly, build this when there was no 25mm version of Primo. I only got this picture on my laptop. When moving into the new workshop is completed I will show my build in a new topic. Myabe until then I have upgraded it to Primo but will still be all in black
Working area is 720mm x 610mm
On this picture you can see a vice mounted to the table, very handy for small parts to machine.
(Yes I know the bottom corners are assembled wrong, made a mistake but figured out it’s no problem at all so I left it this way - never touch a running system)
