Hey, thanks for the reply, I’m excited for the deluge of parcels coming in the mail.
Having looked further into the SPI on the rambo mini, it is software based, basically purposed general i/o pins (good enough for a simple display), that doesn’t seem to be any more solid that uart, probably slower. So it’s not a faster, more robust lane. In theory the standard is potentially faster, just not this implementation. Not 100% how fast the SPI is on the pi is either, come to think of it. Regardless, I am sure things in general will be fine initially, no doubt upgrades will come down the road.
The idea is of the lowrider is simple enough, it feels like something I would come up with, if not get working properly. I recently had the idea of a lowrider with an air brush attached making swooping motions with actuators controling the rate of spray, then I could gcode some ghost flames. Probably not practical, paint everywhere, clogged nozzles, etc, some kickstarter had carburator attached to a phone doing something similar, took them ages to get that going apparently.
Anyway, I found a 5" usb cable that came with one of my projects that I can use, it has to plug into the micro usb adapter, the momentum of that should be fine, some hot glue on the pi’s micro usb port should take care of it, it just seems loose. It doesn’t have the metal slug like my other cable, maybe I can find something to clamp on, if it becomes a problem.
I will probably be starting with foam or cheap plywood, curious how plywood will withstand chipping, aluminum probably not for a while, sounds cool though. Or maye I will start just drawing big ass images.
Thanks for the encouragement.
