I am sure the question has been asked before but i couldn’t find it searching the forum.
Why are the X and Y steppers on the rails that move? It works but it makes cable management a lot harder to get right. If the Steppers were moved to the Left and Back corner mounts then the cable management would be easier.
Pros to the change:
- Easy cable management (No moving wires for X and Y steppers.)
- Less weight for the motors to move have to move around.
- Less Hardware required. A stepper and a single idler bearing per side instead of the current two idler bearing setup.
- Fewer parts to print. (possibly )
- Would require twice the timing belt length. (but it won't stretch so there isn't an accuracy problem.)
- Would require more specific designed parts instead of printing multiple copies of the same corner pieces.
- Move the X and Y Steppers to the corners.
- Redesign the Corners so the legs stick up through the assembly as high as I want.
- So the Z axis can be customized higher or lower for project need. Most of the time will will keep my Assembly low so i only have about 1.5 inches of clearance. But on occasion I may want to work on something that is 6 to 8 inches thick. I know you will say Drop table. But why custom build a table to match my changing height needs if it were easier to just loosen the corners and slide them up the conduit?
- Also I may want to mount a plexy glass shield to those legs if they stuck up a foot above the corners.
- I also considered an idea that would raise and lower the corners with a hand powered mechanical assembly. Something as simple as a bolt sticking through the conduit and a plastic sleeve with threads that goes up or down as it is twisted around the conduit. (This probably won't work with plastic i'll admit)
- Make the Corners about an inch longer on the sleeves so they hold the conduit a little more square.
- Make some sort of an EASY notch for a tape measure to hold onto the corner pieces to help measuring the squareness of the build. That was a very difficult task with a lot of guesswork because the tape measure had nothing to hold onto.
- Find some way to make the moving X and Y parts stay more square when the steppers are disabled. aka when moving the Gantry by hand.
- Maybe make the conduit sleeves hold more of the conduit by a couple inches. Even if that extends an inch or so outside of the machine it could help hold them more square.
- Maybe have a second optional arm/conduit for each X and Y. That might be overkill but it should work.
- I looked over the Auto Squaring option. I may eventually implement that. I am torn between that or eventually making so this machine can be switched back and forth from a CNC to a 3D printer. In that case I would need the other motor drivers for extruders.
- I may just end up buying the Prusa MK3 and leave this machine as a full time CNC.
