Hi everyone! Our makerspace bought a MPCNC kit and were all very impressed with the thoroughness of the design. And then we got to the control side of things.
I have a lot of background in creating the g-code, so no troubles there, but using the repetier host software with the cnc plugin didn’t work the way all the other cnc’s I’ve ran to run the g-code. We meet once a week and didn’t have much time to play with the software as we spent much of the night finishing up the build, but when we got it running, we were not able to zero the readouts nor could we input a value.
So my question is were we doing something wrong in the software and we’ll figure it out at our next meeting? Or does that software not work that way? We did get it moving and even used the 3d side of things to simulate a 3d print and it worked fine. It even moved the z axis up for next print layer.
Here’s an example of what I want it to do : I want to be able to jog to a position “X, Y, and Z” and set zero on the control software screen for all 3.
