repetier dosnt want to play ball with ramps board
I’m not sure if this has been answered already if it has sorry
but I just can’t seem to get repetier host to connect to the mpcnc it will connect perfectly fine to cura but when I attempt to connect it to repetier it just says it can’t connect check settings and com port
When you check the settings, use something other than Auto for the port. I could never get auto to work right and now just cycle through whatever ports shows up in the list until I find one that works.
only 2 ports show up and both say com 4 tried both same message i did get it to connect on my computer but i need it connected to my laptop
Make sure Cura isn’t still running in the background.
