Hi, how can I set this Z to 0(zero)?, even G92 does not work for the Z.
repetier host keeps it’s own idea of what the coordinates are. If you send G92 Z0, the LCD screen will show Z as zero.
To convince RH that it is at 0,0,0, you have to send @isathome
from repetier host, which RH will intercept.
Great you are a genius Jeff.
I’ve tried to use it a few times but it seems to mess up my cutting paths while its connected. Randomly changing a heights, and I paused it once, when I resumed it dragged the tool across the entire project to the left side
