Had to replace my laptop
installed repiter host and made sure that repiter server was not installed
hooked up to machine every thing moves correctly
ran simulation in fusion 360 and was correct
post process to g code and loaded into repiter host
using mini rambo board
ran code and machine just plunges and cuts only in the +y -y for the fitst part second part it does a triangle then will start to cut correctly for a bit than back to crap
this file cut properley on my other laptop
lost ??
her is a copy of the first 50 lines if thegcode
(1001) (MACHINE) ( VENDOR AUTODESK) ( MODEL MPCNC) ( DESCRIPTION GENERIC 3-AXIS) (T7 D=3.175 CR=0. - ZMIN=-10.55 - FLAT END MILL) G0 G90 G94 G17 G21 G53 G0 Z0. (2D CONTOUR1) M5 T7 S5000 M3 G4 P4. G55 G0 X36.513 Y-0.317 Z15. Z5. G1 Z4.6 F333. Z-3.283 G18 G2 X36.83 Z-3.6 I0.318 K0. F1000. G1 X37.147 G17 G3 X37.465 Y0. I0. J0.317 X-37.465 I-37.465 J0. X37.465 I37.465 J0. X37.147 Y0.317 I-0.318 J0. G1 X36.83 G18 G3 X36.513 Z-3.283 I0. K0.317 G0 Z5. Y-0.317 G1 Z1. F333. Z-6.883 G2 X36.83 Z-7.2 I0.318 K0. F1000. G1 X37.147 G17 G3 X37.465 Y0. I0. J0.317 X-37.465 I-37.465 J0. X37.465 I37.465 J0. X37.147 Y0.317 I-0.318 J0. G1 X36.83 G18 G3 X36.513 Z-6.883 I0. K0.317 G0 Z5. Y-0.317 G1 Z-2.6 F333. Z-10.233 G2 X36.83 Z-10.55 I0.318 K0. F1000. G1 X37.147 G17 G3 X37.465 Y0. I0. J0.317 X-37.465 I-37.465 J0. X37.465 I37.465 J0. X37.147 Y0.317 I-0.318 J0. G1 X36.83 G18 G3 X36.513 Z-10.233 I0. K0.318 G0 Z5. X133.563 Y36.512 G1 Z4.6 F333. Z-3.283 G19 G3 Y36.83 Z-3.6 J0.318 K0. F1000.!
