After having used the dual endstop firmware a few times I noticed that if you Home X&Y then move to your start position X,Y, and Z after doing a cut you can Home X&Y again. Rather than manually using the controller to move back to 0 (start of cut) I added a new custom command “G53 G0 X0 Y0”. This let’s me square my cut then return to my start point with one click. It works really well!
I forget, does the standard firmware have cnc coordinates enabled? (IMO it should.) I think it’s needed for the G53.
In Ryan’s it has been on for a while, I think.
