Hi, my name is Rob and I’m living in the Netherlands. I’ve started to order and print (all standard) parts for this build about eight weeks ago.
I’ve been printing with different PLA rolls I had lying aroud, testing several suppliers on the go. For practical reasons (baseplate I already had in my workshop) I decided to build a 640 x 1200mm machine for now, planning to expand it later to 1200 x 1500mm machine. Luckily there is a metal supplier quite close to me that sells overstock materials in numerous dimensions at a fixed price per kg, €3,65 for Stainless steel. For 25mm fine grit polished tubing I could even choose from 5 material thicknesses. I ended up choosing 25 x 1,2 for the side and Z tubes and the legs, 25 x 1.8mm for the middle X and Y tubes.
I ordered belts and pulleys, steppers, bearings, electronics, power supply and 500w spindle motor, all from China, and bolted the lot together on the base plate.
I spent about € 280,- altogether, using bolts and nuts from my stock.
I’ve tested the electronics with the steppers before assembly and the system works fine.
Now I have to wire up the thing, add some parts (Z stepper, X and Y endstops, Z touch plate, cable guides) and do some testing…
It could take me a while, I’m moving to a new house in a few weeks and I still have to pack a few things
I’ll post again when there is some progress made.
