I designed a stool in Fusion 360. I’m attempting to cut out the top.
I used 2 2D Contour’s. The first for the middle slot to mount the legs.
The second for the outside edge to actually cut it out.
It appears that 3/4 of the way through the first cut the router just
stops. I’ve tried using the LCD Smart controller and repetier. In repetier
it says “Job Killed” or something like that. With the controller, It almost
seems to reset.
I’ve had this happen with things I’ve made with EstlCam too.
Any sort of pointing me in the right direction is appreciated.
