Those settings look right. Somehow they are not taking. The feed rates of 80 and “3.000” are strange. They bear no relationship to the feed rates on the tool, not a multiple of 60 or anything you might expect if there were a missed setting somewhere.
Try creating a new tool with different feed rates, say 19 mm/s XY and 6 mm/s Z, just to see what it generates.
On your coordinates.png, check the repeat “f” box. And your speeds are wrong in your tool settings, that usually means you are setting them in the wrong units. In your cncsetup.png mm/min is correct, but you can also set how you want to have the tools settings for speed, I use and recommend mm/s.
Have a look at the milling basics page for some realist numbers.
