Scope creep
I haven’t even started my build and I’m already thinking of things to add…
Need to add a small vibrating motor to the bottom of the shelf the sand sits on. You can turn the motor on and vibrate the table to re-level the sand on it before starting the next design.
This might work with sand. When I was using sand, I could just shake the table by hand to erase.
I have tried a vibrating motor with baking soda - no dice. Won’t even budge.
Personally, I don’t feel a need to level the sand/soda. The next design goes right over the top. You can always print a “wipe” like a spiral or one of the wipes generated by Sandify if you want a clean slate.
If you actually do get a vibrating eraser working though, I’d love to see it!
use a subwoofer… lol :upside_down_face:
The brown frequency?
Lol, maybe you just want to vibrate it flat
[Mythbusters Brown Note](https://www.youtube.com/watch?v=mQFL-NLh0O8)
Little Crystal Method or Infected Mushroom to level the sand. Works best with RGB lighting.
And glowsticks :dizzy_face:
