Screen Reversed on BBT TFT35 V3 E3
I bought the “SKR Pro1.2 + TFT35 V3 E3” package that came pre-flashed.
As I am building a dual-endstop unit I need to re-flash the SKR Pro.
For some reason, call it a brain snap, I decided to re-flash the TFT35 for good luck.
I used the BIGTREE_TFT35_V3.0_E3.26.x.bin as this was the one listed as LATEST.
The flashing process appeared to complete but the screen came up reversed.
Searching for other instances of this in this forum, the solution was to re-flash with more recent firmware.
After several attempts, and sometimes getting “SD Init Failed” I am now left with a reversed screen.
The unit I am building is the LR2 and I have not yet connected the steppers.
Any and all help gratefully received.
Try OK, got a weird one. TFT35 screen backwards - #34 by MrRothy
Fixed - Many thanks.
I had looked through this entry and checked for loosed/ broken wires in the ribbon cable to no avail.
Maybe the system didn’t like the peace-meal way I extracted the files to the SD card.
Now all I need is to install the “Laser/ Router” option instead of “Printer” :wink:
