Hello,
is there any advantage using DIN933 bolts/screws over DIN912?
DIN933: https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcT2aB-rYfmpbT7FmhktjkWAw4UUAFusRCQlCoUBQpSuFf9k54lJxA
DIN912: http://titanwerk.de/WebRoot/Store6/Shops/2d839dab-8771-43ec-a5a6-f5215233c652/5513/B29E/F501/E069/96E4/0A48/3525/5C28/909001329650_m.jpeg
Do note the head of DIN912 is a bit higher.
E. g. in certain places theres not enough space to tighten the screws with a allen key or something like that?
Also, I have a hard time finding one of those M8 x 25mm coupling nuts in Germany (found only a 30mm so far). Should it work to just stack a bunch of common M8 nuts?
EDIT: I just figured the coupling nuts is only needed when threaded rod is used. I ordered leadscrews.
