|Hardware|Alternative|QTY|Comment|
|5/16x1.5”|M8x40mm|46|<- // Hex heads. 13mm if you’re using actual M8s typical, 1/2" for 5/16"|
|5/16 locknut|M8 locknut|46|Typically sizes same as for bolts.|
|M5x30mm||65|Pan head, Phillips screwdriver bit, though mine are 3mm allen key pan heads. 8mm hex head bolts OK MOST USES. Some places will be tight getting into, pan head highly recommended|
|M5 locknut||65|Typical 8mm wrench size nut, required for captive nuts. Careful, some out there are 7mm wrench size!|
|M3x10mm||24|Used to screw motors to mounts. Phillips head OK, 2.5mm hex cap OK, 2mm hex pan head OK.|
|M2.5x12mm|#3x½“|10|Used to attach limit switches. Screw into plastic. Phillips head OK, 1.5mm hex pan head OK, hex cap screws OK.|
