Sd card in Discount LCD
Hey all, I am running into an issue with my LCD. It worked great initially. I want to have more ability to hold it and move around the table, so I bought a long 10 pin cable and installed it. After installing it the screen comes on normally and all appears to work and when plugging in the sd card it says card inserted on the main info screen. But when clicking into the menu it says no sd card. I switched back to the cable that came with the LCD and it works. Is there a length limit on the cable? Any suggestions?
Thanks
2’ seems to be the limit. Some can go a bit longer but not much.
