Second Primo Build
Just got an IDEX printer so Primo #2 in the works. First one was small for aluminum cutting so this one will have a work area of 2’ x 4’ x 4". Got new toolboxes for work so first thing that came to mind was tool cutouts!
That printer looks awesome !
What model is it, do you have a BLTouch for each head ?
SOVOL SV04. Only left extruder has BL Touch and right is manually adjusted to match assuming both gantrys are leveled using parallel shims.
What size was your first one set up as? And how was your success rate with aluminum?
