Setting up new SKR1.2 and TFT
I’m finally getting around to setting up my new board and I have a few questions.
Is it pre-installed with the firmware for dual end stops, or do I need to install that?
The menus on the TFT35 are clearly for a 3d printer (with options for heating, extrusion, etc). Is the the correct software, or is there one that I should download specifically for CNC work?
https://docs.v1engineering.com/electronics/skrpro/
here is a link to the skr setup page. flashing software for the duel endstops is a 30 second job if is not already done
tft will work with that software. there is also a link on the same page to a v1 version
The skr should be flashed with dual endstops from Ryan though.
Thanks so much, I’ve got it flashed, and I’m hooking everything up now.
One other question. Is there a pin somewhere that I can use as a PWM speed control for my spindle?
