I got a slightly different setup on my MP3DP, as I use a BMG extruder clone with a E3D Hotend, also the Bed and glas-plate are bit different. So, I’d like to adjust the starting point where it does the purge line b4 a print, and also when the print does finish, the Y -axis moves a couple of mm too far. I tried to adjust in Configuration.h but it seems I’m tinkering on the wrong spot as changing values seem not to have any effect. I tried to change values here:
//#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
// Specify a park position as { X, Y, Z_raise }
#define NOZZLE_PARK_POINT { (X_MIN_POS + 20), (Y_MAX_POS - 20), 20 }
#define NOZZLE_PARK_XY_FEEDRATE 100 // (mm/s) X and Y axes feedrate (also used for delta Z axis)
#define NOZZLE_PARK_Z_FEEDRATE 5 // (mm/s) Z axis feedrate (not used for delta printers)
#endif
and here:
// Specify positions as { X, Y, Z }
#define NOZZLE_CLEAN_START_POINT { 40, 40, (Z_MIN_POS + 1)}
#define NOZZLE_CLEAN_END_POINT {120, 60, (Z_MIN_POS + 1)}
