solly747
(John)
1
Hi all,
I’m so close to start printing all the brackets etc and start purchasing all the parts. I just want to know a couple things.
Will this (using stainless tube) be able to cut through 5mm aluminium? If not, do you have a recommendation for a machine that will?
I’ve just built a Tevo Tarantula 3D printer and found that pretty easy. How easy / hard is this build to complete and to get it right?
Any advice welcome
Thanks John
1)yup, have a look at the gallery for some examples. But if you want to cut large objects you can make a plasma version for a much faster turn around.
2)In my opinion, the skillset is probably very similar.
solly747
(John)
3
Thanks Ryan,
I won’t need to cut anything bigger than 5mm aluminium, and that’s rarely. It will mostly be for wood.
Now I just have to see what size tube I’ll be able to get locally so I can print the right set.
bigkat
(Jim Hildebrandt)
4
I have used my MPCNC to cut out masonite templates and use a drag tip on my plasma cutter to cut out parts with good results.
