I’ve just ordered the “MOSTLY PRINTED CNC PARTS BUNDLE”, i’ve printed all the parts in 25mm.
What i got left is to decide on the size.
Now, i will get 25mm steel tubes, that is 4mm thick. PN MPa 37,9 and the weight kg/m is 2.07.
Would it be possible for me to go with a working-area of 1m?
Or would that be crazy?
Would Z-axis on 10mm be “sufficient”?
“GT2 Belt enough for any combination of 48" of X and Y axis length”
Meaning if i go 1x1meter in work-size - i dont need more belt?
You are going to need a total of 6x 1.264m tubes, three for X and three for Y. You use two for the sides and the third to move the center pieces around.
A medium/large MPCNC is 2’x2’ best for plastics and softer at that size, until you really get the hang of proper CAM setups.
It is very easy to cut the rails any size you want and just initially put together really really small, 10"x10" work space and expand after you get the hang of it.
If you have placed an order already it will ship tomorrow, today is a holiday. I am printing labels right now so you will have a tracking number by the end of the day.
