Size calculator is not working
Hi,
I am in the process of building the mpcnc Primo. I wanted to calculate the tube lengths but the calculator on the website isn’t showing anything. It doesn’t matter if I take the standard or other parameters. I don’t know if there should be a calculate button or should it refreshing on its own as soon as I change a parameter? The reset button is also not working. Is someone having similar problems or is there maybe something wrong with my browser?
Best regards
Lukas
Just saw it works on mobile but not on my laptop
Probably your browser. It’s your machine that does the math, based on the formulas that the website stipulates. Some security settings will prevent your computer from doing anything based on the web page to prevent it from running malicious code.
What browser? Have you tried a different one?
In the meantime, at least you can get your answers.
I use chrome, but with Microsoft edge its also not working. I use chrome in mobile too, so it looks like a problem with my laptop.
But for me its okay when I can see it on mobile. I just wanted t make sure it’s not a bigger problem.
Same here my CALC Tool doesn’t work sat all on anything ??
