In the assembly instructions, the base is screwed into the table. I was going to set up two tables, one super big 8’x 4’ that would have limited use and a smaller 27" x 52" cutting area. I am trying to order the parts I need in advance, but I don’t see where the screws for the table are provided or described in the bundle. I would like to use an E-Z Lok Threaded Insert and bolt the base to the table and make it easy to unscrew and move back and forth. Could someone please let me know the screw size and I can determine the appropriate E-Z Lok product? Also, how many screws secure each base piece? Thank you!
Fred
