Hey y’all
I do all my drawing in Google SketchUp, does anyone have a good converter to go from SketchUp (stl) to dxf??
Hey y’all
Sketch up should be able to export DXF’s directly. If it is not obvious look for “drawings” or something along those lines.
NOTE: This has been edited from the original.
I spent a few hours messing around with that this morning. I had always gravitated to F360 because exporting DXF is easier, but this time Sketchup was better for the project.
Here’s what worked for me:
If you use components, then these copies you’ve laid out will be updated when you change the original. Good. Use components.
For extra-credit and convenience, choose a spot in your file and create some 4x8 Ruler guides in the XY plane where you can make copies and lay things out. Some of the tutorial videos out there suggest creating virtual sheets with rectangles, but I find that this ends up interacting with the component geometry in ways that are confusing and inconvenient. Better to use Ruler guides.
Also, you can make additional guides to keep things away from the edges, etc.
You don’t have to save the file. So just copy what you want to the clipboard, create a new file, paste, export. So far this is the only way I’ve found to choose which objects are exported.
Now pay attention:
5) Choose File > Export > 3D Model / AutoCAD DXF.
6) Choose Options on the file chooser dialog.
7) Make sure it’s Release 14. Uncheck everything EXCEPT “Edges.” You only want Edges.
Save your file, and ESTL should import it nicely.
