jeffeb3
(Jeffeb3)
September 5, 2020, 3:07pm
21
Parallel is bad. The choices are serial or separate drivers foe each motor (dual, which is needed for dual endstops).
The good news is, I think your firmware is right. You just have to put a driver in the E1 driver port and move the Z2 motor to the E1 motor port.
jafet
(jafet)
September 5, 2020, 4:11pm
23
OK thx , and how i hook Up the endstops tu the board
jeffeb3
(Jeffeb3)
September 5, 2020, 9:42pm
24
jafet
(jafet)
September 14, 2020, 9:43pm
25
HI jeffeb
Sorry for the delay i have alot a work to do
This is my update
All the stepper drive are working OK now
The endstops only x work and an z only one side
And y1 , y2 not working when i home this is my wiring 16001196622303979571812165225901|375x500
jeffeb3
(Jeffeb3)
September 15, 2020, 12:05am
26
Check with M119 before trying to home. That should give you a pretty fast test. All endstops should be wired NC and between - and s.
jafet
(jafet)
September 15, 2020, 1:08am
27
Yes They all are as to say wire nc
Do you think is firmware issue
jafet
(jafet)
September 15, 2020, 1:18am
28
OK all endstop are working but not Y
jeffeb3
(Jeffeb3)
September 15, 2020, 3:14am
30
Does M119 show you that it isn’t working?
It’s possible it is in the firmware.
jafet
(jafet)
September 15, 2020, 3:59am
31
I found my problem They disconecte from the xtenders cable
