so I was running my machine yesterday with no issues. I then started cleaning up and when i went to power it on again it is telling me no printer connected. I’ve made sure all my cables are properly connected and that the it is set to 250,000. I’m not to sure what else to try.
Check to make sure both power supply lines are live.
i do have power across both.
I have the same issue with SKR 1.4 Turbo but its working fine otherwise. It is also missing all the options under the parameters section of settings but I just figured maybe nobody had added a menu into the GitHub files yet. Is it supposed to have all the options there like it normally does?
So it looks like the board shorted out somehow as well as one of the drivers. i ordered a new board and drivers
