SKR Pro 1.2 power wiring help
In my bundle I recieved a 12v power supply, like one for a laptop. The SKR has 2 power hookups one 12/24V and one for the MOTO. Do I need a 2nd power supply for the motors? If not is there any benefit to having 2?
Hello @Vtwin_Guy, are you using a bundle and power supply from the V1E Shop? If so can use the one power supply, just need to wire up jumper cables. Some examples in SKR PRO V2 - Wiring/drivers/screen - #7 by aaronse, hope that helps!
You don’t need two. There isn’t much using the 12V/24V part. Most of the current is used by the motors. Jumpering as Aaron pointed out, is fine.
Thank You! That’s exactly what I was thinking of doing. I always need a pic just to make sure I don`t screw it uo, although it’s not a guarantee that I won’t :wink:
