SKR Pro V1.1 & V1.2 connecting to dm542 drivers
can you connect SKR Pro V1.1 & V1.2 to dm542 motor drivers. And if so how to go about it.
I am just taking a guess here but you can probably just wire up the en step and dir and be done. Searching wiring external drivers to ramps board will probably get you real close. In the end the driver sockets on all the boards are the same and the ramps is the most popular but you could search any board. The key is an external stepper driver.
