Good morning all,
first of all please excuse me for my english but i use a translator.
I come to you because I have a “no printer attached” problem on my screen that I cannot resolve at all despite a lot of research.
I have:
Bigtreetech BTT SKR V1.4 Turbo
TFT Bigtreetech 3.5 V3.0
And I use firmaware:
TFT35_V3.0.026.x jul 13 2020
V1CNC_SkrTurbo_DualLR_8825-2.0.7.2-src
my connections seem correct to me,
Thank Jeffeb3
Yes, I have modified the config.ini file with a Baud of 250K
then 250K in the parameters on the screen.
Yes indeed in Marlin mode it works but I would appreciate not having an error on the touch mode side
I once again check everything,
I modify the configuration.h #define SERIAL_PORT -1 #define SERIAL_PORT_2 0 #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
I checked that the baudatre is the same on the tft and the skr but I still have this error message
I have had 2 SKR boards from V1. Look at the cable connections on the board and TFT, and make sure EXP1, and EXP2 are oriented correctly. The third cable can be an issue getting in firmly. Make sure it is the right way by the SKR docs here, https://docs.v1engineering.com/electronics/skrpro/
With all that said, both of the boards I have will say “No Printer Attached” for about 10-20 seconds after power on until those communications on those cables are established. This appears to be normal.
your right @jeffeb3… I could have sworn I saw “Pro” somewhere…
@julienr, @JohnSherman describes the same as my experience with the 1.4 Turbo, the board takes a few seconds to fully boot up and the error will remain until it completes the boot process. once booted up the error will go away.
Hello John, thank you for your answer but yes I tested all the possible combinations without success.
I am thinking of a hardware bug, I recommend a new card
Ah, it seems your TFT firmware is a bit out of date, which may be causing an issue. Do you know how to precompile your firmware for the TFT, it is basically the same for when you should have compiled it for your marlin firmware. Click the green “code” box, download zip file, unzip/decompress, and open it with coding software (VSCode is free). From there you’ll see a config.ini, open this with VSCode and edit to your device specifics, make sure your baudrate matches marlin and build it, and copy it over to an SD drive to put into your tft it should update. In addition, BTT github has other specifics that may be necessary for the TFT35 to work properly.
BTT TFT Firmware: (replace the (DOT) with a period)
https:// github (DOT) com/bigtreetech/BIGTREETECH-TouchScreenFirmware
