I have this slight wobble in my core as shown here.
I’ve taken the core apart several times I’ve even reprinted the core cause I had a slight layer shift while printing. No matter what I do I cant get that wobble out of the core. I’m getting lines while I cut on certain sides. If I’m watching what is happening I see the dewalt shift a little and I’m sure it’s due to this wobble.
Any ideas what is wrong? The 2 clamp bolts holding the core are tight while the tension bolts are fairly loose cause the machine is pretty square naturally, now. I’ve tightened the tension bolts and that didn’t help. I’ve taken the core apart and reassembled a couple times already with no improvement.
