I normally first remove the fuse to see if there is any visible damage and then I test function using my multimeter set to continuity. You should have a symbol similar to this
You will get an audible tone if the connection is intact.
Caution : Make sure you disconnect power to your board prior to doing any work on it!
Thanks…I knew that but does it apply to those nano fuses…or whatever they are called? The small ones on the rambo board.
Yes, it should work on the removable SMD fuses as well.
I forgot to mention to make sure you disconnect power to your board prior to doing any work on it!
Thanks…and I did power off the board. I couldn’t get continuity so the motors fuse is bad. That’s a relief…I thought I had bricked the board. I ordered more fuses from V1…supposed to be here Tuesday…so I’ll find out for certain. Thanks again for all of your help.
