I can use the Marlin Classic screen fine but not touch. “No printer found” but at this point don’t care.
Using the classic mode of Marlin I do not find anything on the TFT SD card. I d/l Repier host and tried through that. I went looking for the gcode and it thinks it’s a txt file.
A notebook is hooked up to the SKA and I can move the core around.
Gcode files are just text files with the extension .gcode. You should be able to load it with RH and then hit print. Make sure you set the 0,0,0 first, or put G92 X0 Y0 Z0 at the start of the gcode.
That’s what I thought but they are shown as text. I will work on it. I did use Estlcam and saved and it is now visible. I am usually a Mac guy except for Fusion 360 and maybe I have the extension shut off.
New question. What controller do I use in Estlecam? SKA not there?
