All parts bought from V1. Rambo board, LCD. Finally had time to start setting up and got it powered. I had a loose wire that kept the LCD from turning on. Got that figured out, but now it won’t let me toggle in the menu. The button works to get into the menu from the main screen but it doesn’t toggle when turning the knob. There was a couple times it would toggle to the second menu but never past. Seems like the knob/switch may be at fault but I’m uncertain. I tried paging through the forum so I wouldn’t have to bother anyone but I haven’t found anyone having similar issues.
update:
I tried unplugging and swapping the wiring and also reversing the connectors and now it will move the toggle but it goes directly to the menu from the main screen and the button no longer works so I can’t select any of the menu options.
UPDATE
I couldn’t leave well enough alone and looked at my ender 3 and realized it used the same cable for the lcd. I swapped it out and sure enough I got the mpcnc responding. Now to move onto learning the programming so I can actually use it to carve something.
