[SOLVED] MPCNC MRambo Error on power up
So I just finished putting my MPCNC together, but I am having some trouble getting the electronics set up.
When I first plugged everything in I was getting a periodic flash on the LCD, but nothing else so I went through the process of re-flashing the firmware after that didn’t solve it I read in a post on the forums that the LCD connectors could be put in any orientation harmlessly so I gave those a spin and finally got the boot screen, afterwards I got dumped to the home screen with the message" “Err: EEPROM Version”.
The values for X,Y, and Z are flashing between “0” and “?”. Couldn’t find anything on the forums about it already, my guess is something to do with the firmware, but I am not really all too sure.
Thanks in advance,
James
EDIT
It appears that all I needed to do was load the defaults and store them…everything seems to be working now so I’ll continue on. I won’t delete the post though for anyone that runs into a similar problem!
The flashing between ? and numbers is normal.
Apologies, fixed it on the current version.
