I have built a LR2 with a kit from Ryan and am having issues with skipping steps i believe.
I had issues on one design, so i tightened all the belts.
See pics for skipped steps.
For the small batman, i have successfully cut this out of 3mm cardboard several times from the same GCode, and I have not updated the firmware from when i got it all working.
I am running dual endstops, Z max/ Y min. Single End stop X min.
Dual connected Y & Z steppers.
Router table is made from welded steel, with MDF top and MDF spoil board.
Table size is 3000mm x 1500mm giving roughly 2560mm x 1290mm working area.
Made from a kit from Ryan, 3d printed parts in PETG as i’m in australia and it get very hot in the shed…
Tubes are Steel, ERW tube, 1" diameter, 2mm wall thickness
Â
Â
Any help would be apreciated.
Â
i keep seeing amazing projects turned out by V1 engineering designs on the facebook group, but i’m struggling to restore the accuracy i had previously?
Nice. When my machine skips step, it makes a crunchy noise like grinding gears. If it’s not making that noise, then it’s something mechanical (like the loose pulley).
