I set my MPCNC axis’s to where I want them to be zero using he LCD unit, then I reset the rambo board and all my axis show zero on the LCD unit. However sometimes when I reset rambo the z axis tries to drive down through my table. Also after I run a program the z axis tries to do the same thing even though the end of my g code has the z axis going to +10 mm.
Also is there a way to setup the auto home function on the LCD panel. When try to auto home all axis’s try to go past the physical limits.
