Just wondering if anyone has a source (US preferable) on extensions for the stepper motor cables. Things are a little too tight for comfort with my current wire routing.
Poking around the forums it seems most people are DIYing it with varying success. I am more than comfortable clipping the current wires to add some length, but I would need to buy the wire any way. I thought a properly crimped extender would save some hassle, but I cannot find anything with the correct male to female connectors.
I made the mistake of adding my own extensions. Connections landed inside rails, even with tape and little to no movement, I had a limit switch connection fail. So I had to pull everything back out and made 1 long wire for each connection, only connections now are at the board and at the motors.
