Found no official dimensions, but I know I read about the dimensions of the spacers somewhere on the forums, so I though this are the correct ones. When I assemble the wheels it looks like this: https://imgur.com/a/8aY8jIx
Are the spacers not the correct size or the wheels?
It doesn’t matter that much as long as the wheel doesn’t easily move on the bearings. They make spacers specifically for skate wheels, there are a few different sizes. The ones I carry are 10mm and fit both inline and skateboard wheels.
If you’re a longboard rider, you have to choose a larger one. On the other hand, if you have a skateboard, a smaller one is better suited for you. If the wheel is small, it has a smaller surface area to distribute your body weight, so balance is a little bit hard to achieve.
While a bigger surface means a much easier way to balance.
