Spindle is not straight
Hi! My spindle is a little angled which show here the 1inch dia surface bit not parallel to the board, right side is a little higher than the left side. Which one should i adjust? Thanks
The search term that you’re looking for is “tramming”
Search the forums for that, and you’ll very likely find someone who has solved the same exact issue.
Check the gantry pipes first and make sure they are coplaner to the table before shimming anything. Chances are your gantry is twisted a bit.
Actually I accidentally move axis to left while the bit touching the surface which causes the gantry to bend.
Do printed parts can be easily deformed with that? How can i check without disassembling?
That doesn’t sound right. There might be a slight but not deformation.
mine was slightly off, I shimmed the mount by sticking a folded up sheet of aluminum foil between the router and the mount to push it in the direction i needed it to go in.
Lazy, but it worked.
That what i did also. Tried adjusting but just got slight improvement only. Still not straight
