Hi guys, trying to wrap my head around the whole feeds/speeds/stepover tool settings.
I’m trying to surface my spoilboard (3/4" MDF) with this bit:
You can see that when I separately run a rectangle around the perimeter, the finish is perfect. Using the same bit/settings, when I try to pocket out, there are a couple things I notice. I stopped the job and what you see is only during the first pass (so -1mm on the Z):
The upper left side (MDF is uneven and this area is deeper), the bit is just skimming the surface and it looks like it is burning.
The right side has noticeable rings. This would be an issue with my stepover setting?
Both of these issues are easily solved with a palm sander and light sanding with 80-grit, not the ideal solution
Here is a photo of my issue, my setup in Estlcam and what the toolpath looks like in CNCjs.
Thank you for any help with understanding the tool settings – or something else I may be misunderstanding/doing wrong!
