Squaring Trucks
Are there any better instructions on how to square trucks than this document?
My Y-axis is slightly greater than 1/8" off. I can’t seem to straighten it no matter if I tighten or loosen those 4 tension bolts.
Hi Rob,
I have realized a tool for it PRIMO Core-Adjustment-Tool for High Precision and Stability
On my PRIMO it works perfectly but to be honest I do not exactly know, if it can be used for other constructions than 25mm. Needs to be tested.
If you need any modification for the parts, no problem, give me a message.
You can not adjust the trucks with the core on.
You make your trucks as perfect as you can get them, then you know they are right. Next step is add the core and only adjust the core, the trucks are not to be touched with the core on.
@anon74685196
Sorry, I should have had a better look to the image. You are right. Of course it is not possible to adjust these things via the core.
(at)Ryan is someone else, @vicious1 is Ryan.
Sheesh, what a way to make @anon74685196 feel good about him self…
Poor other Ryan. I am sure you are a great Ryan. I’m sorry you get called in so much.
I am fairly confident if I here Ryan, I would have turned off my notifications a long time ago.
Thanks to all of you… including the fake Ryan. :slight_smile:
